Ok folks, need some input here. I've hooked my gas furnace up to be able to run off my generator by following Rick's DIY on YouTube (sorry first post so I can't post links). The basic setup is using an appliance extension cord to power the furnace with a single plug outlet so that the furnace can be unplugged and plugged into generator. Also, my furnace is on a dedicated circuit.
On my setup, I have an emergency shutoff switch that is fed by a box in the ceiling directly above the furnace (attic above, romex cable exposed). I installed the outlet below the switch and thinking I might be wrong. In the event of a power outage, how would the thermostat receive power? Would having power go to the furnace from the generator also provide power to thermostat? Also, would it be wise to turn off the breaker? I don't want to risk having the generator running and the power come back on. Should I have put the outlet above the shutoff switch?
I also considered installing a Reliance Furnace Transfer Switch but have the same concerns. Where would this be installed in line? Above shutoff switch, below? Or would I knockout a hole in the box the shutoff switch is on and feed it into that and tie everything together inside that box? I can add pictures in necessary.
Every modern HVAC system I have ever seen has the transformer located inside the blower cage. Supply AC to the furnace powers the transformer which uses the thermostat wire to power the thermostat.
You may want to read this post. Generators are not recommended for furnaces if they have a electronic circuit board as the power is not clean as the frequency varies with the speed of the generator.
Ayuh,.... Not that I would advocate breakin' codes of any sort, any where, any time,....
In a life or death situation,...
You plumb in the generator, between the switch, 'n the furnace,....
In the event we're talkin' 'bout, you'd turn the switch Off, to break the connection to the grid,....
Then plug in yer generator,....
Before ya ever try this,....
Flip the Main Breaker at yer electrical entrance, for safeties sake,....
Even though the switch at the furnace is Off,....
When a generator is hooked to a house, the Main, absolutely has to be Off,...
I didn't watch the video but I'm pretty sure it's a simple matter of unplugging the furnace and then plugging the furnace into the generator. Absolutely no chance of backfeeding the grid because the generator is running the furnace only.
An inverter generator should be safe from what I've read. I have a Yamaha 2000 watt that I was going to use. Thought the larger style generators were the dirty power type.
as long as it does not have a mechanical governor/speed control like your basic Honda/Coleman. If it has a electronic speed control or converts the power and they guarantee the frequency/hz/hertz and voltage are stable then it may be safe. If the voltage or hz drops then your board will get damaged.
when using generators always follow the safety guidelines to the t...including providing the proper disconnects to protect the linemen working on the system ..you don't want to send power to them while they are working to restore your power...
The furnace should directly(extension cord is okay) plug into the generator. The emergency switch should not be in the picture, nor any of your other house wiring.
I hook up a lot of generator panels using a subpanel and interlockit kit. The generator provided by customer. The things they usually want are:
lights
kitchen
furnace
computer/tv
Their generator,their problem?
I have a Yamaha inverter generator hooked up to a transfer switch connected to essential circuits including the one for my modern high efficiency gas furnace. These generators control voltage and frequency electronically so they do not vary with engine speed. And because of this many of them are designed to run at slower speeds than conventional generators so they are quieter and easier on the engine. On this generator my furnace runs as normal.
Is the furnace install in the attic , your transformer is probably hard wire out side the furnace and not getting power to step down to 24 volts for your thermostat. The generator need to get power to your thermostat first than plug your blower.
You’ve posted in a 6 year old thread, and the member you quoted hasn’t logged on since posting this thread.
Related Threads
DIY Home Improvement Forum
3.1M posts
320.1K members
Since 2003
