Old 01-08-2013, 11:31 PM   #1
gas furnace flue replacement
I just had the transite pipe removed from my house and I need to install a type B flue pipe from the furnace. There is a chase where the old heat pipe was and there should be plenty of room for the new type B pipe (1 inch clearance). I will be running horizontally for about 8' from the heater in the crawl space into an unconditioned laundry room. Then into the chase up through the first floor, then through the attic and out to the roof. How many firestops would I need in this case?
From what I read from Duravent and others is I will need one from the laundry room through the joists in the first floor into the chase and one as the pipe exits the roof. Do I need another perhaps at the top of the chase where the pipe enters the attic area? I just had a contractor here at the house and he had no idea what a firestop was! Thanks in advance for your help.
Granger72 is offline   Reply With Quote
Old 01-08-2013, 11:52 PM   #2
fire stop for every floor here.......
carmon is offline   Reply With Quote
Old 01-09-2013, 12:37 AM   #3
Experienced HVAC Tech
Same here. i kinda can't believe a contractor wouldn't know what a firestop is.
HVAC1000 is offline   Reply With Quote
Old 01-09-2013, 12:46 AM   #4
Thanks for your replies. I was astounded as well. Southern CA is full of these types...
So that's one firestop at the first floor penetration and one at the roof? Also, where the chase enters the attic area, the framing is lower in this section than the overall attic elevation and the blown in insulation can fall down into the chase. If I fit and cut sheet metal to extend vertically above the insulation layer will this be safe and comply with code? The chase itself is simply framed and has insulation on one side to weather.
Old 01-09-2013, 01:11 AM   #5
if i understand you correctly then yes you can fit a cuff around the flue (at least an inch away) to keep the insulation from falling in on the flue. just make sure as you said to be an inch away from flammables, including drywall
Old 01-09-2013, 10:39 AM   #6
Roofmaster
Everything I have ever read about flues calls for 2 inches minimum clearance. Has this changed recently? As far as firestop goes, I assume you mean Rock Wool, or unfaced, compressed fiberglass, and not the traditional in wall wood firestops.
" A lot of men build things, and a lot of things fall down "
Old 01-09-2013, 11:37 PM   #7
From my hands on experience with double wall ( B-vent) flue pipes the code ( Around here at least) says only 1 inch from flammables. Also with all brands of double wall each piece has a sticker on them that specifies only one inch clearance from flammables.
Old 01-10-2013, 06:40 AM   #8
An old Tradesmen
The hole is 2" bigger then the pipe. Which gives you 1" clearance all around the pipe. Maybe he is confused on that.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 11 12-16-2012 07:18 AM
furnace replacement and evaporator coil leak Armylis HVAC 4 10-02-2012 10:04 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
gas furnace replacement mjimenez HVAC 24 10-27-2011 11:38 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
