Gas Furnace Flue Clearance - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 02:26 AM   #1
Rewards Points: 180
gas furnace flue clearance
I'm installing a furnace and it was placed so the flue went thru a load bearing wall. It chard (sp?) the wood near the flue. I moved it so that it doesn't go thru the wall but I want it as close to the wall as I can get.
This is a nat-gas wall furnace and has an oval flue, and I haven't seen any flexable flues.
Is there something I can put between the flue and the wood to prevent fire?
I was thinking about several sheets of galv steel plates with washers in between to create air space.
KarlJay is offline   Reply With Quote
Old 08-26-2011, 04:35 AM   #2
An old Tradesmen
Rewards Points: 8,234
Look at the install manual for its required clearances.
You would need atleast a 1" clearance rom the wood using sheet metal.
Old 08-26-2011, 06:05 AM   #3
Rewards Points: 1,216
You should check what type of vent pipe you have going through the wall to the roof. Is it B vent which is double wall ?
COLDIRON is offline   Reply With Quote
Old 08-26-2011, 03:19 PM   #4
Rewards Points: 180
It is double wall and mentions 1" or 4F29 Firestop spacer. I googled 4F29 firestop and got nothing related.
Old 08-26-2011, 04:56 PM   #5
Yes with class B vent you should have one inch clearance around the entire pipe. You should be able to purchase class B spacer bases which are square with the inside round like the diameter of the pipe, you nail the spacers to the wall or chase then feed the B vent through that and its keeps it one inch away from combustible material all around.
Old 08-26-2011, 05:58 PM   #6
Rewards Points: 180
Guy at the local fireplace shop said to use Durarock non-combustable sheet rock.
Anyone know anything about these non-combustable sheets? I understand they are sold at HD/Lowes.
Sounds like cheap insurance to me.
Old 08-27-2011, 04:40 PM   #7
REP
Durarock is used behind fireplace units that are just outside the wall,usually in a corner.It has a fire rating.
That is what I would consider overkill but it certainly wouldn'hurt anything as long as all exposed wood and normal drywall is covered with it.
Like others have said ,what you need are a few firestop metal pieces .They are cheap and anybody that sells oval b" vent will have them..When installed in the chase and the B vent is installed in them,it will hold the vent the proper 1" away from combustibles.
Now all that said I would check and find out if your unit is exceeding the required temp rise.Ifd thats the case you might have problems with the vent,any blower on it or even gas pressure or wrong size orfice.
good luck
REP is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
New Furnace Install AustinPorsche HVAC 1 05-12-2011 10:16 PM
flue pipe on 90+ furnace Landen HVAC 31 02-14-2011 08:29 AM
would there be any lead-based coatings inside a gas furnace or flue? Dave Perry HVAC 1 05-14-2010 08:02 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
