Gas Furnace Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2007, 08:18 AM   #1
Gas furnace flue
Gents, I just built a new garage.
I was given a propane gas hot air furnace, supposedly in good shape, to heat it with.
Is there a way to vent this thru the side wall?
What type of vent pipe is needed?
Is the vent piping for oil the same? (in case I decided to switch in the future)
Thanks, Al
econoline is offline   Reply With Quote
Old 11-21-2007, 09:00 AM   #2
Rewards Points: 150
The answer depends entirely and totally upon what the furnace manufacturer lists as valid forms of venting for this model. Locate and read the documentation.
Far as switching to oil - again, entirely depends on what type of vent an oil furnace is specced for. However, ceramic-lined masonry chimneys usually have to be relined when switching fuel types. Steel vents might only require an inspection and maybe a cleaning.
scorrpio is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 06:10 AM
