Gas Furnace Flashes- 3 Times- AS Freedom 90 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 04:04 PM   #1
Gas Furnace Flashes- 3 times- AS Freedom 90
I have an american Standard Freedom 90 Gas Furnace that does not light. There is a flashing light on the control board that is flashing 3 times. The thermostat is calling for heat. The code for 3 flashes says pressure switch error. What trips the pressure switch? I found what i believe to be the switch ( micro switch attached to a small diaphragm ) with clear hose attached. What do I look for in troubleshooting the problem. Thanks in advance for your help.
varambler is offline   Reply With Quote
Old 11-20-2010, 04:45 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Check the plastic vent pipes outside for blockage.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
american standard freedom 90 fault code flashes 6 times db1020 HVAC 5 01-14-2010 05:56 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
