Old 11-07-2010, 07:59 PM   #16
Gas Furnace Fan Occassionally Keeps Running After Burner Shutdown
You are obviously not a REAL contractor. Down here in the South if it's attached to the house, it needs to be replaced.
"well I can see that your unit is x years old and so is that old 12 gauge copper wire that connects it to the power panel. I suspact that you wpuld want to the do the right thing and upgrade to the correct 14 gauge wire (plus installation) right?"
You'll want a duct cleaning with that to keep your family safe too...
barryfish is offline   Reply With Quote
Old 11-07-2010, 08:06 PM   #17
An old Tradesmen
Maybe you should just call real HVAC service company. A big add in the Yellow pages doesn't mean alot.
There are replace everything companies everywhere. But if you look around enough. You find companies that know the difference between a furnace, and an evap coil.
Old 11-07-2010, 08:19 PM   #18
best regards,
Superheat
Old 11-10-2010, 09:52 PM   #19
Professional
these furnaces had problems with the relays on the control board going bad. one is a heating relay, the other is cooling relay, almost always the heating relay would stick!
hvactech126 is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 09:38 AM
furnace burner problem brent h HVAC 2 01-11-2010 08:50 PM
Furnace won't stay running H. Phillips HVAC 0 01-05-2010 12:51 PM
Goodman Furnace Burner issue hansim4 HVAC 5 10-08-2009 08:26 PM
