Gas Furnace Fan Keeps Running - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 12:27 PM   #1
Gas furnace fan keeps running
I have a really old Weatherking gas furnace, and the fan runs all the time. Replaced thermostat (needed replacement anyway) but problem persists. Could only stop fan by switching off power. Then I looked inside control panel and found tucked away under panel a 3'x6" grey box, only id is White-Rogers, inside label label says limit control. Its too new to be OE, and there is a long slide switch that is labeled Automatic/Manual. The switch was in the center. Switched it to auto and now the fan seems to be working properly, so far. Question is, is there any good reason for the switch to be positioned as described, why wasn't this a problem before, and what is this switch called so I can find out more about its purpose?
Thanks in advance.
mongo1 is offline   Reply With Quote
Old 02-22-2011, 01:46 PM   #2
Rewards Points: 1,596
A picture might help someone identify the part and related items.
bob22 is offline   Reply With Quote
Old 02-22-2011, 02:54 PM   #3
Thanks, Bob22, but I'd have to get one of my kids to do it.
I think the switch was the problem, and possibly vibration caused the switch to move into the "null" position. Now that its set to auto it seems to work ok.
If it is in fact a limit switch, when should it be set in the manual position? And does the manual setting cause the fan to run even when the thermostat was telling the fan to shut down?
Thanks again for your response.
Tags
gas furnace , weatherking
When running furnace on fan only..... Zombify HVAC 10 12-23-2010 06:58 PM
Gas Furnace Fan Occassionally Keeps Running After Burner Shutdown Dr_Zoidberg57 HVAC 18 11-10-2010 08:52 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 06:01 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
