Old 01-30-2012, 09:39 AM   #1
Gas Furnace Exhaust Venting Question
I noticed that basement was unusually warm in late January (even though it's been a mild winter so far in Chicago) I noticed there was a lot of heat coming from the furnace exhaust near the furnace. It's as if there is a loose connection. 2 questions;
1. Is this heat dangerous? Common sense says exhaust is not healthy.
2. Should this be happening... the "heat leak"
The house was built in 1995 and I bought it in 2011. When I first moved in, I noticed that the ducts had many leaks at the joints. I was told to buy foil tape and wrap'm up. I guess it worked but the air in my 2nd floor master bedroom is still weak, that's another topic
bulls847 is offline   Reply With Quote
Old 01-30-2012, 10:14 AM   #2
I'm Your Huckleberry
It'd be comparable to asking if sucking on your your car's exhaust pipe is something to worry about.
It should exhaust to the outside of your home and no where else. No leaks.
Thanks.
Doc Holliday is offline   Reply With Quote
Question about changing to high efficiency gas furnace ohman HVAC 23 01-19-2013 05:10 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 06:51 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Make up ventilation through return on furnace question creamaster HVAC 8 09-27-2009 05:53 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
