Old 10-08-2012, 11:19 PM   #1
Gas furnace comes on then goes off
Gas furnace comes on then goes off stay on about 2 second i just install a White-Rodgers 50M56U-843 a/c works great it is a Rheem unit (Gas Furance)
Texasbill is offline   Reply With Quote
Old 10-08-2012, 11:25 PM   #2
what comes on the burner....better description will help us
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Texasbill (10-08-2012)
Old 10-08-2012, 11:28 PM   #3
Yes the burner,comes on then goes off after 20 seconds.
Old 10-08-2012, 11:32 PM   #4
JJboy's Avatar
flame sensor dirty????
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Texasbill (11-13-2012)
Old 10-08-2012, 11:36 PM   #5
great place to start.... clean it
Old 10-08-2012, 11:51 PM   #6
New senor came with the kit I position the senor in the center of the flame tube it glow and ignite the gas for about 20 second.
Old 10-08-2012, 11:57 PM   #7
Rheems are famous for the pressure tubing plugging or the port on the inducer motor plugging...check that as well....
Old 11-13-2012, 09:13 PM   #8
Thanks all for your input final got it to stay on the wiring harness did not have the flame senor wiring going to the flame senor I found it out after troubleshooting the wiring on the unit and connection wiring kit (White -Rodgers) Thanks again .
The Following User Says Thank You to Texasbill For This Useful Post:
ben's plumbing (11-13-2012)
Old 11-13-2012, 09:20 PM   #9
that explains a lot......
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
