Gas Furnace, Burners Wont Stay On - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 03:51 PM   #1
gas furnace, burners wont stay on
Hello everyone. I am having a problem with my gas heat in my house. Two days ago my heat stopped working, completely out of the blue. I went into my crawl space to check it out, and I havent been able to fix it completely yet. My pilot light never goes out, but the burners only light if I press down the "reset" button on my thermocouple. I normally only have to press the button when I am doing my initial lighting procedures at the beginning of the season. Once I press the button, the burners light up, the fan will come on, and voila I have heat! But as soon as my inside temp reaches the desired temp, the burners cut off and will not come back on until I go back into my crawlspace and hit that darn button again. Any Ideas? I was thinking it was probably a bad thermocouple, but Im not exactly sure. The unit is probably about 25 years old, natural gas forced air heat, and the type where the pilot light is always burning.
Any help would be greatly appreciated.
-Mike
mikerva is offline   Reply With Quote
Old 01-19-2012, 04:49 PM   #2
HVAC Tech/ Browns Fan
Is that hook up to a Johnston control thermo control safety box? Note are you having to relight pilot?
Tator1076 is offline   Reply With Quote
Old 01-19-2012, 04:58 PM   #3
The pilot always stays on, it never extinguishes
Old 01-19-2012, 05:01 PM   #4
Trane furnace works for a few hours, then burners will not fire peacebunny HVAC 16 01-16-2012 01:46 PM
Gas Furnace Won't Stay Running / Thermostat Set High To Start _scott HVAC 6 03-23-2011 08:27 PM
RUUD gas furnace wont stay running co5j HVAC 23 01-14-2009 06:47 PM
Furnace burners flame out after a few seconds snurb HVAC 3 01-13-2009 08:58 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
