Gas Furnace Briefly Shutting Down - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2009, 07:59 AM   #1
Gas furnace briefly shutting down
Hi,
I have an induced gas furnace w/electronic spark ignition that's about 15yrs old. I'm in Texas. The furnace will run fine for quite a while trying to reach temp but before it gets there it will shut down. It doesn't shut down completely though. The draft inducer motor continues to run and it will restart within a minute (the pilot goes out and relights). Always restarts on the first attempt.
When its very cold and running for a long time it will do this several times before reaching the desired temp. When it doesn't need to run very long to get to temp it doesn't happen at all. I tried the following:
New T-stat
New filter
Clean furnace/burner area
Any idea what this might be?
Thanks.
John
john152 is offline   Reply With Quote
Old 12-26-2009, 09:01 AM   #2
HVAC Tech/ Browns Fan
Flame sensor
Tator1076 is offline   Reply With Quote
Old 12-26-2009, 09:54 AM   #3
Originally Posted by Tator1076 View Post
Flame sensor
That's what I thought after doing some searching but it seems like the flame sensor issue occurs when the pilot will light for a few seconds. Mine will stay on for long periods of time, go out briefly then come back on. The pilot doesn't go out right after it lights.
Old 12-26-2009, 09:54 AM   #4
Your furnace is probably overheating and opening the high limit switch. This is normally caused by a lack of airflow through the furnace. A restrictive or dirty filter, dirty evaporator coil, over fired burners or inadequate ductwork are usually responsible for high limits opening.
SKIP4661 is offline   Reply With Quote
Old 12-26-2009, 05:35 PM   #5
Thanks for the reply. I'll try your cleaning suggestions. I also hear kind of a clang of pipes about one minute before it shuts down. Could that be significant?
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
furnace shutting off mary d HVAC 4 03-28-2009 07:57 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace not shutting off pkuenz HVAC 5 11-17-2008 04:22 PM
