Old 10-12-2007, 02:34 AM   #1
Gas furnace "bangs" when stopping
Got woken up this morning by a "bang" and had no idea what it was. The next time the furnace cycled off, I found out. The gas furnace seems to be coming on every couple minutes, and when it shuts down, it does so with a BANG. I guess it could be a CLANK or a THANK!
Any suggestions? It is blowing warm air, at least, it's just hard for me to sleep.
Beren is offline   Reply With Quote
Old 10-12-2007, 12:02 PM   #2
How old is the unit?
redline is offline   Reply With Quote
Old 10-12-2007, 12:08 PM   #3
I'll check tonight and see.
Also, I realized last night that the banging is not coming from the furnace itself. I think it may be coming from the ducts.
Old 10-12-2007, 12:17 PM   #4
What may be happening is that when the blower shuts off the ducts "relax" from the pressure drop. You may be able to find the location of the duct that is flexing and secure it to reduce the amount it flexes.
Old 10-12-2007, 12:22 PM   #5
Understood. I'll check for loose ductwork. What confuses me is that this did not happen during the summer when the A/C would shut off. Same blower, same ductwork.
Old 10-14-2007, 09:24 PM   #6
The duct may have just loosened up?
Old 10-15-2007, 08:37 AM   #7
It sounds like you got a damper someplace that is opens/closes when air pressure comes on. There will usually be a rubber bumper to cushion the damper, but if the bumber has worn off, the damper's door would bang directly against the housing.
scorrpio is offline   Reply With Quote
Old 10-15-2007, 09:37 PM   #8
Have you done any reno's or anything where you may have changed the amount of airflow the unit is moving. Have you pushed any furniture up against the return air ducts or blocked any of them off by accident.
Ussually cooling is run at a higher speed than heating if your furnace has a multi speed fan. It could be possible that the wires could be reversed and you are now on a higher speed.
You could check by switching your fan setting on your tstat to "fan on" and shut back off and listen for the noise. Of course check and make sure the filter is clean(I would supose that was your first thought, but I had to ask)
HVACDave is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
