Gas Furnace In The Attic HELP? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 12:00 PM   #1
Gas Furnace in the Attic HELP?
I'm a rookie here so please be nice! So, we have an attic that we are converting to a family room. The attic already has the gas furnace and has been properly zoned with vents and intake for the space. My question is do we need to insulate the entire attic space including the area where the furnace is or do we just insulate and knee-wall around the furnace area thus keeping the furnace are exposed to fresh air through the soffits?
Thanks - Jason
JasonDavid is offline   Reply With Quote
Old 02-03-2012, 12:04 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
It would certainly be against code to have the furnace in any living area.
Is that the intention?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-03-2012, 12:26 PM   #3
In Mass its pretty common to have an attic with the furnace to support heating/cooling for the below second floor...its new home so I'm assuming everything was to code before we bought it.
Old 02-03-2012, 12:28 PM   #4
Not if it was there all the time. . to the OP : is your furnace an 80% or 90% model?
hvac5646 is offline   Reply With Quote
Old 02-03-2012, 12:34 PM   #5
AndyGump's Avatar
Rewards Points: 688
Oh I see what you are asking now that I re-read your post. The furnace will be in the side attic area behind the knee wall. Dough!
Usually that is fine as long as you have the proper combustion air for the furnace in that area but there are a lot more things to consider than just the placement of insulation in a project like you are describing.
Proper type and placement of insulation for the rafters and knee walls, not to mention venting if required and proper sizing of lumber for the floor members now that it will be living space, etc.
Andy.
Old 02-03-2012, 12:45 PM   #6
Hcav5646...it is an 80% model with an aluminum flue pipe through the roof.
Old 02-03-2012, 12:52 PM   #7
Make sure you have a dedicated combustion air source from out side. Usually a four inch 26 ga pipe will suffice.
Old 02-03-2012, 12:55 PM   #8
Yes Andy, the furnace is located in a corner right under the ridge of the roof. The knee wall will be built all around the attic and around furnace itself according to code with access doors for maint. But I guess the main question I have is whether to create a little furnace room separate from the finished/Insulated space in the attic? Any thoughts?
Old 02-03-2012, 12:58 PM   #9
It may already have one but if it does not I'll have the HVAC guy come out to add it. That being said does that mean I can keep the furnace inside the insulation zone?
Old 02-03-2012, 01:00 PM   #10
AndyGump's Avatar
Rewards Points: 688
Sorry, I can't really give you any advice on that as I don't know the entire scope of what you are trying to accomplish. It would just not be right of me to do so.
I would need to know what codes are for your local for insulation and a lot of other things as well as what the present construction of the house is etc.
Andy.
Old 02-03-2012, 01:04 PM   #11
Andy.
Its not a problem...its a complicated thing! I'm just sad I don't live in So Cal like you.
Thanks for your reply's...much appreciated!
The Following User Says Thank You to JasonDavid For This Useful Post:
AndyGump (02-03-2012)
Old 02-03-2012, 01:42 PM   #12
biggles's Avatar
just keep in mind service and access to it,but build it around as a hallway furnace with louver door might be....guy comes to service it is money and time to you battling the enclosure
Old 02-03-2012, 01:54 PM   #13
Ya..we have having an access door to get to the space for cleaning and changing the filter and maintenance issues. Thanks
Old 02-03-2012, 01:54 PM   #14
AndyGump's Avatar
Rewards Points: 688
Good thought, needs 36" min. in front of the service door to the furnace for service access, and a light in there switchable at the room access.
Andy.
Old 02-03-2012, 02:11 PM   #15
Rewards Points: 6,652
Andy.
It is common here to see them in a closet in the living area.
Tags
attic , furnace , hvac , insulation
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Furnace install in attic - Duct configuration hartkem HVAC 6 11-08-2008 05:46 PM
