Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 08:27 PM   #1
gas furnace
blowing little heat out vents /blowing cool air out the return
Mr.Bigga47 is offline   Reply With Quote
Old 03-06-2011, 08:42 PM   #2
Experienced
Jackofall1's Avatar
Welcome Mr.Bigga47, to the best DIY'r site on the web.
It really helps to have specific information when asking these types of questions, when was the last time you changed the filter, is this happening with that fan running?
What is the model and make of the furnace
The more information you provide to the forum the better responses you will get.
Mark
Old 03-07-2011, 06:08 AM   #3
hillbilly guru
Send a message via Yahoo to hvacguytn615
need more info as jackofall1 has already said .has any work been done recently
hvacguytn615 is offline   Reply With Quote
Old 03-07-2011, 06:10 PM   #4
it's a GE and that makes it past it's life expectancy . Replace it with a new one.
hvaclover is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
