Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2010, 12:48 PM   #1
Dak
gas furnace
can a gas furnace put off a kerosen or sulfur smell. The exhaust outside smells like sulfur at times furnace is in its second season
Dak is offline   Reply With Quote
Old 12-17-2010, 03:49 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
Is it Propane?
Old 12-18-2010, 10:32 AM   #3
Dak
Natural gas 95 efficient two years old also it sounds like its missing when its running. when you go out side where the exhaust and intake are.
Old 12-18-2010, 10:50 AM   #4
Hvac Pro
yuri's Avatar
If it is running properly there should be no smell. Only water vapor and CO2. Get it checked ASAP as it may not be burning properly and carbon etc may plug up the heat exchanger and damage the furnace.
Old 12-18-2010, 11:16 PM   #5
Dak
thank you
Old 12-19-2010, 07:23 AM   #6
An old Tradesmen
Rewards Points: 6,074
Does it get its combustion air from inside the house, or from the outside?
Could have dirty burners.
Old 12-19-2010, 11:41 PM   #7
Dak
It draws from the outside and return in the house
Old 12-20-2010, 05:22 AM   #8
An old Tradesmen
Do you mean you have a fresh air duct connected to your return duct.
Old 12-20-2010, 01:37 PM   #9
Dak
The outside air comes in in 3" pvc pipe rigjt into the furnace and i alo have 2 exsisting cold air returns
Old 12-20-2010, 08:02 PM   #10
An old Tradesmen
Ok, its a direct vent system then. So its combustion air is from the outside.
So you shouldn't be getting any fumes from the intake.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
