Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 09:46 PM   #1
Gas Furnace
I have a Rheem gas furnace model RCCA-10EC that needs the little circuit board that is located on top of the gas valve just under where the thmalcouple fastens. The 5 pins that are attached to the board are broken. I took it apart and went to the parts store. The man told me that it is against the law to take that apart and that I would have to buy a new valve. $235. WOW! I think that the assembly is called the ignition control module. Was the man right about buying a whole new valve or can i just buy the part that I need. Thank you.
looyboy is offline   Reply With Quote
Old 01-24-2010, 10:32 AM   #2
I don't know about the gas valve part but your posting ws under Carpentry. You might have better luck posting it in Plumbing??
geoff hall is offline   Reply With Quote
Old 01-24-2010, 05:43 PM   #3
Repost under HVAC there's a lot of good knowledge over there.
Sounds like the guy was right usually them things can't be taken apart or tampered with. Sucks don't it?
SULTINI is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
