Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 05:38 PM   #1
Rewards Points: 16
gas furnace
In a gas furnace does the stainless steel flue chimney ever need to be cleaned? no conversion from coal or oil,original gas.
sjay is offline   Reply With Quote
Old 06-03-2009, 07:32 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,448
The chimney part going out of the house is usually aluminum as stainless is very expensive. If the furnace is maintained/burning cleanly it does not need chimney cleaning but the chimney should be inspected for corrosion etc internally.
Old 06-03-2009, 08:24 PM   #3
Good luck not breaking it even if you wanted to clean it.
All liners made of aluminum weaken at the top after so many years of use and would pull apart if cleaning was attempted.
hvaclover is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
