Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 02:49 PM   #1
Gas Furnace
We have a normal gas furnace system. This past weekend I noticed a exhaust smell when entering the house. Is it possible the exhaust is backed up? It is not a constant odor. I checked the unit itself and smell nothing there or at the hot water hearter. Those are the only 2 gas appliances
dbaird is offline   Reply With Quote
Old 01-22-2013, 04:00 PM   #2
That depends, doers your furnace and/or water heater have a vent motor, or do they use natural draft?
Systems with a vent motor have a proving switch, if your flue is backed up it won't allow the unit to run. Older systems however can allow exhaust to back up into the house. For instance I looked at a house the other day with an older furnace/water heater venting through a chimney. The chimney was clogged and whenever the furnace would run the only place the exhaust had to go was the water heater flue. So all the furnace exhaust was leaking out of the water heater flue. The entire top of the water heater was covered in soot. Fortunately the house was vacant.
So yes that can happen. If you think that's the case I'd recommend having a pro look at it. Carbon Monoxide is not something to fool around with.
JScotty is offline   Reply With Quote
Old 01-22-2013, 05:14 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
Buy 2 new CO detectors if yours are older than 5 yrs old and put 1 by your bedroom and the other in the stairwell to the basement. Also get the furnace and chimney checked by a Pro.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (01-22-2013), COLDIRON (01-22-2013)
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
