Old 11-26-2010, 04:31 PM   #1
gas fireplace-Replace thermostat w/switch
we have a ventless gas fireplace with a thermostat. on occasion, fireplace will automatically start up (dangerous). we want to replace thermostat with on/off switch. is that possible? is it a special switch (heat resistant)?
rbm328 is offline   Reply With Quote
Old 11-26-2010, 04:48 PM   #2
GC/Master Plumber/Mech
any swith will work, single pole/single throw
Suggest that you mkse it like a wall mount light switch
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-30-2010, 06:45 AM   #3
firestarter
jhon wayne was a great actor but people are here for help and that phrase can be missleading.
firestarter is offline   Reply With Quote
Old 11-30-2010, 08:05 AM   #4
HVAC / Plumbing
how so ?? I see nothing wrong with it. He's been here since 09 & your the only one to mention anything about it
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
Anti-wingnut (11-30-2010)
Old 11-30-2010, 07:01 PM   #5
i'm just looking for a switch i can keep in the firebox. do they make such a thing?
Old 11-30-2010, 07:42 PM   #6
If the thermostat is mounted on a wall, why not replace it with something like a Honeywell 1000 heat only thermostat? It has a built in on-off function and sometimes a regular wall type switch tends to create a great deal of resistance causing a "no heat" situation (will not light) if the fireplace only uses a millivolt type circuit.
GotHeat is offline   Reply With Quote
Old 11-30-2010, 07:47 PM   #7
If the thermostat is mounted on a wall, why not replace it with something like a Honeywell 1000 heat only thermostat? It has a built in on-off function and sometimes a regular wall type switch tends to create a great deal of resistance causing a "no heat" situation (will not light) if the fireplace only uses a millivolt type circuit.[/quote]
Thanks for the reply.
no, my problem is that there is a thermostat (w/thermocouple) attached to the fireplace gas unit and a dial is the adjustment for the temp setting. i want to remove this switch and replace it with an on/off switch so it doesn't come on automatically.
Old 11-30-2010, 08:37 PM   #8
Professional
is this dial on the gas valve? If so you are talking about a snap action hydraulic gas valve. If this is the case. You would need to replace not only the gas valve, but potentially the pilot assembly, add a thermopile and then wire in a wall switch.
I may be off and not understanding, but from the sounds of it, this would be necessary if your gas valve has the dial on it.
hvactech126 is offline   Reply With Quote
Old 11-30-2010, 08:46 PM   #9
dial is on the gas valve.
my last home had gas fireplace w/pilot lite. when we wanted flames, we turned up the valve and it ignited just like a stove would.
thats what i'd like to get back to, instead of a fireplace that acts more like a furnace and automatically comes on when the temp drops. i was trying to get by, by hopefully just replacing the thermostat with an on/off switch instead of a new log set.
Old 11-30-2010, 08:53 PM   #10
Professional
you are going to have a lot of time and money wrapped up in this..... also not to mention a dangerous situation if you are unfamiliar with working with gas appliances. It can be done, but I don't recommend by a DIY person. Best to get a pro involved, but by the time you do that, you may be getting into putting a different log set in.......
Old 11-30-2010, 08:57 PM   #11
always looking for a less expensive alternative, but also know that sometimes its better to take the high road. guess i'll be ordering a new log set.
thanks for all your help
Old 11-30-2010, 09:47 PM   #12
HVAC / Plumbing
sounds like you have a thermostat controlled set of logs. Like he said. You will have a set with pilot generator to operate off a light switch. Would cost too much to convert
Thermostat replacement goalie35 HVAC 2 11-13-2010 03:10 PM
new honeywell RTH4300 thermostat to replace older one randysd Electrical 4 09-03-2010 11:20 AM
Fireplace Smell ...help wanted ! jasonb72 General Discussion 6 08-26-2010 07:02 PM
New Thermostat issues when cooling guimond777 HVAC 2 05-04-2009 11:46 AM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
