Gas Fireplace Fan Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 08:58 AM   #1
Rewards Points: 14
I have a gas fireplace insert and when I turn the blower fan on it will start to make a loud almost grinding noise after some time... Needless to say, it does not sound like it should.
I'm thinking it's either some kind of dirt or dust in the fan motor or blades... or perhaps some kind of bearing?
Any ideas how to fix this? Or is this something that needs to be replace? I was hoping to get away with a vacuum and a couple shots of oil if possible...
Thanks!
ldogg is offline   Reply With Quote
Old 12-18-2012, 09:04 AM   #2
Rewards Points: 14,026
Only one way to see if that will fix it, do what you suggest.
Old 12-18-2012, 09:12 AM   #3
Missouri Bound's Avatar
You are in a much better positionn to tell us what worked....clean and lube is always a good first step.
Do you want it your way or the right way?
Old 12-18-2012, 09:26 AM   #4
Roofmaster
Rewards Points: 2,210
Yeah, try A, if no work go to B. Vats da Problem?
Old 12-18-2012, 11:23 AM   #5
how
Rewards Points: 1,104
Many fireplaces are installed with fans that look like aftermarket parts.
Meaning the fan&motor are not actually secured in place. You can hope that it has moved out of place and the cage is coming in contact with something it shouldn't but 95% of the time, that motor/fan assy will need to be replaced
how is offline   Reply With Quote
Old 12-18-2012, 12:45 PM   #6
Rewards Points: 14
Ok, thanks for the info! Seems like I was on the right track anyway...
Any recommendations where to get a manual online to see how to remove the motor/fan assembly?
Also, in the event that I have to replace the motor, any recommendations for online parts suppliers? I called my local supplier and it sounds like I'm looking at around $250 just to replace the motor!
The unit is Insta-Flame Model# DV36RN
Thanks!
Old 12-18-2012, 05:46 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Thanks!
Ayuh,.... In this case, Google is yer friend,...
"Insta-Flame Model# DV36RN" produced this,...
Check page 29, fig. 45, 'n 46...
You have the optional fan kit.... part # 50-954,...
Donno if Sherwood is still 'round or not...
Old 12-18-2012, 07:02 PM   #8
there are numerous blowers for fireplaces on ebay, amazon, and bizrate for under 100.00 but it is only the blower that is inside the unit you show in your photo.
Old 12-19-2012, 10:07 AM   #9
Rewards Points: 14
Thanks for the info!!!
All great resources...
I noticed my fan does not look quite the same as the one in the photo, and more of the "hamster wheel" kind. Perhaps it is after market to begin with.
I think I will start with taking it out and oiling/clean to see where that gets me.
fireplace ticking noise pkoglman Building & Construction 3 10-29-2012 10:07 PM
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 09:05 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
noise from fireplace FRUSTRATEDnKY General DIY Discussions 4 12-24-2007 03:23 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
