Gas Fireplace Exhaust - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 12:53 PM   #1
gas fireplace exhaust
I have a continental fireplace,12,000btu, it is top vented with a 4"/7" exhaust pipe, I have the termination box for the exterior wall. I am going through an area that has been sprayfoamed(2lb foam) is there any clearance issues that i should be worried about? I have hi-heat caulk for the joints, I know my termination needs to be min 12" from any window/door. If I cut a 8" hole to slide the vent out can I sprayfoam(expansion foam) it in to place?
dhubz is offline   Reply With Quote
Old 12-11-2010, 01:09 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
I doubt it. Check the manufacturers instructions. Spray foam is not fire rated. Phone a reputable fireplace distributor and ask them what they use. Failure to do it properly and you may void your house ins. Fire inspectors can determine where and how fires start easily.
Old 12-12-2010, 09:32 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I am currently installing my direct vent fireplace with the same 4", 7" piping ,my directions call for a 10"x11" framed opening through the wall. I believe that will give you enough aar space between the pipe and the insulation.
hardwareman is offline   Reply With Quote
Old 12-13-2010, 05:48 AM   #4
An old Tradesmen
Rewards Points: 6,560
Yep, you need to check the install manual for required clearance, along with your local codes on it. Spray foam is generally not approved to be used against a high temp surface.
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 07:53 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
