Gas Fireplace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 08:57 PM   #1
jho
jho's Avatar
Gas fireplace
I'm not sure if this is the right forum to be discussing this, but I've been thinking about installing a gas fireplace in my home. I live in a bungalow and have a chimney stack that runs from the basement all the way up through the middle of my home, but the fireplace was removed before I bought the house. I was thinking for up in the bedroom in the second level, putting a gas fireplace in the chimney stack. Is this possible?
jho is offline   Reply With Quote
Old 11-14-2011, 10:09 PM   #2
This question can not possibly be answered with out seeing the stack, and the house.......there are literally hundreds of hvac shops in your area.......let your fingers do the walking.......
harleyrider is offline   Reply With Quote
Old 11-15-2011, 05:22 AM   #3
jkv
You may need to put a steal liner in that flu if you want to run gas but harleyrider is right with out looking at what you have and knowing type of gas/ vented/nonvented/size/ect. we could not help you and know that you will be safe. Get a HVAC co. out there to look at what you are wanting to do,it is not worth you are your families life.
jkv is offline   Reply With Quote
Old 11-15-2011, 06:20 AM   #4
jho
jho's Avatar
I'm glad I asked, because I wasn't too sure. Thanks guys! I'll try to get someone out this weekend.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 11:37 AM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 09:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 06:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
