Gas Dryer Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 02:06 AM   #1
Rewards Points: 1,062
Question
gas dryer venting
is there any difference in venting an electric and gas dryer? i am changing to gas and was just gonna have a duct going about 4 ft vertical and then direct through the wall. just like i did for electrical.
Old 09-21-2011, 06:26 AM   #2
That is OK. Just replace with new rigid(smooth) metal pipe. None of that corrugated flex stuff, please.
The Following User Says Thank You to Just Bill For This Useful Post:
amakarevic (09-21-2011)
Old 11-14-2011, 02:55 PM   #3
one more question: is there a clearance requirement for that pipe like there is 6" if i were venting a gas water heater? or can it get in touch with lumber, for example?
thanks
Old 11-14-2011, 10:48 PM   #4
Venting for the lint does not require the same clearances as venting for flue gases. So you should be fine.
VIPlumber is offline   Reply With Quote
Old 11-15-2011, 01:52 AM   #5
yeah but it's a gas dryer
Old 11-15-2011, 07:20 AM   #6
Rewards Points: 1,216
Gas or Electric don't matter their all thermostatically controlled. You are talking about apples and oranges here with the exhaust from a dryer compared to a heater.
Heater flue temperatures are much higher than a dryer exhaust. It's a different ballgame with heaters.
COLDIRON is offline   Reply With Quote
Old 11-15-2011, 07:34 AM   #7
Chicago, IL
Michael Thomas's Avatar
the usual warning is:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-15-2011, 02:52 PM   #8
Rewards Points: 87
I have a simular situation. I just had a 17 KW whole house generator installed and have to rearrange the vent for my gas dryer due to how the installer had to run the entrance cable to get to the transfer switch.
The original vent pipe was the corrugated metal type and I have noticed that it has about 1 to 1 1/2 inches of built up dryer lint inside the vent pipe. Bad idea in my book.
I am planning on using PVC schedule 80 4 inch piping instead when I run the new vent pipe. Reason I am doing this is I feel that the PVC will be slicker on the inside and less likely to hold onto lint. I of course will use a short piece of the corrugated stuff going from the dryer to attach to the pvc pipe. I can clean this out easily if need be. I think I can also put air pressure on the PVC piping and blow it out in the future, if I need to.
Does anyone have any comment for me on this project?
I will be getting someone to do this for me as I will have to go through my brick exterior wall and I am getting a little too old to tackle this even though I usually do all my work.
Tom
Tom
TGMcCallie is offline   Reply With Quote
Old 11-15-2011, 06:02 PM   #9
I wouldn't install any thing else but 4" round galvanized pipe for a dryer vent. With the joints in the direction of flow and taped joints.
Old 11-15-2011, 06:42 PM   #10
Chicago, IL
Code and manufacturer's installation instructions prohibit PVC dryer ducts
Previously discussed here
The Following User Says Thank You to Michael Thomas For This Useful Post:
TGMcCallie (11-15-2011)
Old 11-15-2011, 09:38 PM   #11
Rewards Points: 87
Mike, thanks for the hyperlink referral to previous post about 4 inch pvc as dryer vent piping. Very informative.
Tom
Old 11-16-2011, 02:34 PM   #12
Registered User
Rewards Points: 5,516
The 2012 whole she-bang, click on "next section" after reading (1-5) and follow the links posted: http://publicecodes.citation.com/ico..._15_sec002.htm
Gary
Tags
dryer venting , gas dryer venting
Dryer venting mulkernrj Plumbing 6 08-20-2011 12:25 PM
Need some advice on venting a dryer. John_W Building & Construction 9 06-26-2011 10:34 PM
Dryer Venting Question cbzdel HVAC 4 05-18-2011 02:16 PM
Vertical dryer venting oatlord Appliances 4 04-04-2011 01:26 PM
dryer venting too short? Mike L Appliances 11 09-23-2009 11:26 PM
