Gas Dryer Vent Vertical - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 11:06 PM   #1
Rewards Points: 1,062
Question
gas dryer vent vertical
i have a stackable laundry set and the gas dryer exhaust is at the very bottom of the appliance. from there the hole in the wall is 6' up, almost directly above (so no diagonal travel). is this too much and will it reduce the efficiency of the dryer?
i mean, i have it all set up and it dries fine BUT i was wondering if it would be significantly more efficient if it were close than 6', to the point that it would justify drilling another hole in the brick wall?
thanks
Old 12-31-2011, 07:25 AM   #2
It should be fine the way it is. Residential dryers want a static pressure of under .5" and total vent length 20' or less with 3 elbows. Your 6' vent will not improve by getting shorter.
The Following User Says Thank You to Marty S. For This Useful Post:
amakarevic (12-31-2011)
Tags
dryer
New dryer vent moisture n0c7 HVAC 23 10-30-2011 05:02 PM
Dryer vent installation Wiscbldr Building & Construction 3 05-04-2011 03:14 PM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 12:26 AM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
