Gas Dryer And Gas Fireplace Not Working Simulatenously - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 09:49 AM   #1
Gas dryer and gas fireplace not working simulatenously
Hi there- I noticed last night that my gas fireplace will not work when my gas dryer is running... is this a common issue? If so, what can be done? If not, should I have someone come out to look at it? Thanks! Any advice is appreciated!
worked is offline   Reply With Quote
Old 08-02-2010, 10:09 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,090
Sounds like the gas pressure regulator at the gas meter or the meter itself is failing. Call the gas utility and have them check it.
The Following User Says Thank You to yuri For This Useful Post:
worked (08-02-2010)
