Old 02-02-2010, 07:39 PM   #1
Gas dryer--4" duct reduced to 3"
We just purchased a new gas dryer and noticed when examining the ductwork that the 4" elbow is reduced to 3" to go through the wall to the outside.
We have a 90 degree elbow out of the back of the dryer connected to a 2' long rigid duct connected to another 90 degree 4" elbow connector. This connector joins into a reducer (2-3" long) and directly into a 3" duct run through the wall to the outside (approximately 8" looks like). Is reducing down to 3" to go through the wall going to be a problem?
mvmposton is offline   Reply With Quote
Old 02-03-2010, 07:11 AM   #2
Not sure about your local code, but it would not fly here.
IRC M1502.3 says, duct size "as required by manufacturer". Most manufacturers recommend 4".
Old 02-03-2010, 09:27 PM   #3
Remodeler
adpanko's Avatar
I don't know if it is a code issue, but I'm sure the dryer instructions will say to not reduce the diameter of the vent at all. It definitely isn't a good thing. I don't know if it is horrible though. It just may take more energy to dry your clothes and the duct work will probably clog up faster than it otherwise would.
adpanko is offline   Reply With Quote
Old 02-04-2010, 07:31 AM   #4
Never seen one reduced and have seen quite a few, just keep it 4" like all the other millions of dryers in the USA.
It's 4" all the way out for a reason.
SULTINI is offline   Reply With Quote
Old 02-05-2010, 09:15 AM   #5
Thanks, we plan to replace with 4". This home was built in 1952 and I have since have been told that a 2.5" hood was common at that time.
Old 02-05-2010, 09:25 AM   #6
Military Mom of 4
Snav's Avatar
It will suck a bit to enlarge the hole but it's the smartest thing to do. . . good luck.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Using 4" PVC for dryer vent Thurman Appliances 9 06-30-2010 11:44 PM
Install dryer duct booster or find a shorter vent route? dinosaur1 Appliances 7 12-02-2009 01:26 AM
Dryer Duct Run Ddeck HVAC 6 10-10-2009 06:52 PM
Hole in my dryer duct... QuattroStylez Building & Construction 6 11-30-2008 05:11 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
