Gas Dryer - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 06:15 PM   #1
Rewards Points: 117
Gas dryer
I have a gas dryer. It turns on but does not heat up.
Can someone please explain.
Does the dryer have an electronic pilot??
mustang64 is offline   Reply With Quote
Old 02-05-2014, 06:35 PM   #2
Rewards Points: 582
gas or electric..ben sr
Old 02-05-2014, 07:46 PM   #3
Rewards Points: 117
It is a gas dryer
Old 02-05-2014, 07:47 PM   #4
Rewards Points: 117
It is a gas dryer.
Old 02-05-2014, 08:35 PM   #5
An old Tradesmen
Rewards Points: 7,770
Might want to post brand and model number of your dryer.
Old 02-05-2014, 10:04 PM   #6
Rewards Points: 117
It is a Whirlpool heavy duty - super capacity.
Does this help??
Old 02-05-2014, 10:06 PM   #7
Rewards Points: 117
Model No. YLRG7647EQ3
Old 02-05-2014, 10:17 PM   #8
Rewards Points: 117
Would a back draft in the exhaust pipe have something to do with it as a safety feature??
Old 02-06-2014, 04:19 AM   #9
An old Tradesmen
That would only cause a problem if it was stuck closed. Remove the burner cover and see if the ignitor is coming on.
Old 02-06-2014, 05:04 AM   #10
Rewards Points: 117
I'll try that. Would that be the only issue or could there be others??
Only asking for the reason that if the ignitor does come on.
Tx.
Old 02-06-2014, 05:18 AM   #11
Rewards Points: 13,960
For some reason that model #'s not coming up, you did not include your location in your profile so I''ll make a guess your not in the US.
Here's some general info on dryers.
http://www.repairclinic.com/RepairHe...er-Repair-Help
Your post is confusing to me. You say it's coming on, but not heating. What's "coming on"? The flame, the drum is turning?
Old 02-06-2014, 05:32 AM   #12
Rewards Points: 117
Sorry about that.
I'm in Canada and yes the drum is spinning but no heat.
Tx.
Old 02-06-2014, 04:04 PM   #13
An old Tradesmen
Tx.
Ignitor not coming on could be caused by a bad control board, bad ignitor, bad electrical connection.
Old 02-06-2014, 04:47 PM   #14
Rewards Points: 117
Hello beenthere,
How and which one do I tackle first??
Old 02-06-2014, 04:49 PM   #15
An old Tradesmen
Remove cover/panel to see if the ignitor tries to light the gas.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
DRYER HELP or Bigger Problem? SitEatChat Electrical 19 05-05-2012 01:12 AM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 06:18 PM
