Gas Boiler Will Not Shut Off!! - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 11:12 AM   #1
Gas boiler will not shut off!!
I have a Peerless gas boiler the burner will not shut off. I have just purchased the house and the boiler hasn't been on for a while. I have replaced the sensors and installed a new thermocoupler and aquastat. It does have intermittent pilot light controlled by a honeywell smart gas valve. I heard that when the gas valve is bad the boiler will not shut off. I just wanted to check to see if anyone has had this problem before I spend money on a new valve.
karldl is offline   Reply With Quote
Old 10-27-2011, 04:59 PM   #2
newtech's Avatar
Rewards Points: 164
What is the water temp getting to when it does not shut off?
Some boilers keep the water temp off the operator vrs the t-stat.
Might need to re-control the boiler to run off the the t-stat.
Post model # of the boiler.
newtech is offline   Reply With Quote
Shut off boiler for the summer? secutanudu HVAC 2 08-01-2011 11:34 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
How do you shut down an OLD gas boiler? mudpaw HVAC 2 07-23-2008 05:02 PM
boiler shut off... marks5894 HVAC 5 01-05-2008 09:07 PM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 11:49 AM
