Gas Boiler/Gas Water Heater Exhaust Size - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2007, 01:28 AM   #1
Unhappy
Gas boiler/Gas water heater exhaust size
I have a 35+ year old house with a baseboard boiler furnace. I recently had a home inspection done and the furnace exhaust and water heater exhaust are tied into the same exhaust pipe. The inspector said that he thought the pipe had to be upsized on the out side of the junction when the two are tied together. Mine is not. DIY what is the standard?
Tim Lucas is offline   Reply With Quote
Old 02-03-2007, 09:35 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi Tim Lucas
The general mechanical code calls for the pipe size to be increased 1" above the primary heating devise. When the increase is made it is supposed to be done where the secondary device is connected. Example: Boiler has a 5" flue, the flue should be 5" until it gets to the water heater. The water heater will be 3", where the two flues intercect or tee however you want to say it. From that point to the end of the flue should be 6". However this does not apply in all city codes. Check your local mechanical codes to verify what is required.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 02-03-2007, 09:46 PM   #3
Exhaust pipe sizing
Thank you. Repair already done and this is what I thought and installed the proper size.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
