Gas Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 06:07 PM   #1
gas boiler
How do I install a millivolt gas valve in gas boiler?
baken1 is offline   Reply With Quote
Old 10-14-2011, 07:31 PM   #2
Electrical Contractor
kbsparky's Avatar
Are you wanting instructions on the wiring of this valve, or the piping?
-KB
Last edited by kbsparky; 10-14-2011 at 07:36 PM. Reason: Moved to HVAC forum, reworded response
Old 10-14-2011, 07:32 PM   #3
DIY staff
Rewards Points: 7,174
I moved this to HVAC for you---
Old 10-14-2011, 10:06 PM   #4
REP
Ifr you are thinking that this will allow you to run the boiler in a power outage or in a cabin without power,it won't.
You would still need power for the circulator ands any other line voltage control.
REP is offline   Reply With Quote
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
