Garage / Shop Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2007, 04:06 AM   #1
Garage / Shop heating
Gents, In my past I have heated my shops with old Miller oil hot air trailer furnaces...but...they worked but not like I wanted.
With that said, in my new garage I'm thinking oil, hot water (Dowtherm or eqivilent) with old radiators...
Can anyone give me some feedback on the oil boiler reliability....being fired up intermittantly...from ice cold starts....used on weekends mostly.
Thanks, Al
econoline is offline   Reply With Quote
Old 12-08-2007, 10:05 AM   #2
The shops I've worked in have usually used overhead propane blowers. There's nothing to freeze, they're simple, are cheap to install, and they heat the place up faster than a boiler system.
NateHanson is offline   Reply With Quote
Old 12-09-2007, 04:34 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,.......
Unless you fill the boiler,+ radiation with Antifreeze,....... It'll just Freeze solid, destroying the boiler,+ the radiation....
Other than that,....... It'll work Just Fine.........
New Heated Garage: need help! HardcoreCBR General DIY Discussions 12 05-23-2008 07:34 AM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 08:41 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 11:09 AM
Moisture problems when 'heating only when needed' in insulated garage? timg HVAC 10 01-18-2007 05:38 PM
heating garage farrington135 HVAC 2 12-05-2006 02:15 PM
