Garage Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 08:42 AM   #1
Rewards Points: 77
Garage Heater
Does anyone know of any 120v electric garage heaters that can be thermostatically controlled and heat a small space (500 sq/ft) reasonably well?
Graham
gjones is offline   Reply With Quote
Old 12-16-2011, 08:59 AM   #2
The standard oil filled 120V heaters will work, but you need more then one, probably a lot more then one.
bungalow_steve is offline   Reply With Quote
Old 12-16-2011, 09:04 AM   #3
Remodeler
Rewards Points: 330
Most portable electric heaters have built in thermostats, I have a couple of the oil filled radiator style that we use in the basement and both have built in thermostats. They do a great job producing even heat and don't have the exposed hot elements. If you plan to use simple plug in type 120 volt heaters you are limited to about 1500 watts.
500 sq ft is a good sized space to heat with these small wattage electric heaters you will almost certainly need more than one. How well any heater is going to function is dependent on how well that space is insulated and sealed up.
If you have open rafters, stud cavities and uninsulated doors you are going to need a lot more heating power to raise the temperature to a comfortable level.
iamrfixit is offline   Reply With Quote
Garage gas heater ronlin HVAC 2 12-05-2011 06:29 PM
Garage heater gmbwrenchn Electrical 12 10-11-2011 04:32 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
$59 "vent free" heater for garage? pcampbell HVAC 2 03-26-2008 02:24 PM
