Fuse Compatability - HVAC - DIY Chatroom Home Improvement Forum
Old 07-15-2011, 03:07 PM   #1
Fuse compatability
I have replaced a 1/6 HP 1 Amp. 208-230 Volts ,RPM 1075 with a 1/5 HP 1.6 AMP, 208-230 Volts, RPM 1075. I have replaced the capacitor 370 VAC with another 370 VAC. I need to replace the fuses' however, the writing is worn. Can I use a 20AMP 250 V fuse (2 of them) or do I need another size?
Last edited by xsoccrplyr; 07-15-2011 at 03:43 PM. Reason: wrong volts on Capacitor
xsoccrplyr is offline   Reply With Quote
Old 07-16-2011, 07:18 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
You need to know the recommended fuse size on the condensing unit. Look at the data plate on the condensing unit. Make sure the replacement fuses are hacr rated.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-16-2011, 07:25 AM   #3
An old Tradesmen
Rewards Points: 8,184
Yep, cause if they aren't, you'll be replacing them often.
big fuse problem randallatha Electrical 6 01-02-2011 11:07 AM
HVAC fuse ejconcepcion Electrical 7 01-17-2010 03:46 PM
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
