Old 01-17-2012, 08:50 PM   #1
Furnance Problem
The main burner turns On and goes Off and about 30 seconds.
I cleaned the heat sensor and checked the limit control switch
chinaman is offline   Reply With Quote
Old 01-18-2012, 08:44 AM   #2
Master General ReEngineer
Bondo's Avatar
Furnance Problem
Ayuh,... What kinda furnace,..??
There ain't no mind readers hanging out here...
Old 01-18-2012, 09:11 AM   #3
biggles's Avatar
Furnance Problem
Hi limit how is the filter and is the fan squirrel cage clean on the fins....do you have a control module inside the furnace...
Old 01-18-2012, 10:14 AM   #4
Furnance Problem
I have a Comfort maker furnace high eff that fires up and then shuts down and then fires back up and shuts down not sure what could be no flash codes on furnace
Bryan nowicki is offline   Reply With Quote
Old 01-18-2012, 01:05 PM   #5
Furnance Problem
bryan, do not hijack threads.......please make your own.....you will be helped much faster
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
ben's plumbing (01-18-2012)
Old 01-18-2012, 09:24 PM   #6
Furnance Problem
chinaman even though you cleaned flame sensor ..your problem still seems like flame sensor....maybe replace sensor...I have clean sensors that still did not work ...replaced it now working fine..
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 06:20 PM
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
