Furnance Blower Fan Noise! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2009, 03:41 AM   #1
Rewards Points: 150
Spray WD-40 into Furnace Okay?
when the furnace kicks on an intermittent squeeking occurs. it is a WeatherMaker 8000TS by carrier. squeeking or however one describes the noise of any old blower fan needing some lubrication.
is there an easy fix?
please skip to 2nd post in this thread. THX - r
-rosco
Last edited by rosco; 12-26-2009 at 06:08 AM. Reason: topic not explaining my question
rosco is offline   Reply With Quote
Old 12-26-2009, 05:56 AM   #2
Rewards Points: 150
Question
How difficult to replace blower fan?
how hard is it to replace the blower fan of a carrier Weathermaker 8100TS interior HVAC unit? product: 58TUA100----12116; model 58TUA100-16; series 120; serial 3000A61374
i'm looking at diagrams and it is greek to me. removing one and replacing with the same thing is monkey see/monkey doo. no prob.
power will be shut off at breaker and checked before touching anything. no worries.
Thanks for any help from someone who has done this before.
-rosco
Old 12-27-2009, 10:00 AM   #3
HVAC Tech/ Browns Fan
If it is oilable it has port on the side of the motor. It will have a yellow cap. But it sounds like a new motor will help. It can be hard to replace it and pull the motor from the wheel. Some case it better have someone to do it.
Tator1076 is offline   Reply With Quote
Old 12-27-2009, 01:05 PM   #4
Spin the wheel by hand. If it makes noise then the problem is the motor. If it only does it on the torque of start up then the blower wheel is the likely problem.
Old 12-28-2009, 10:03 AM   #5
Rewards Points: 150
if the wheel is the little black wheel in upper panel of this unit (better described above) it makes no noise when turned by hand.
the sequence: something runs (that makes the squeek); then the furnace flames light and the little black wheel spins. so the squeeking starts before the little black wheel starts spinning.
Over the weekend the squeeking has went away. not sure why it made so much noise. but it prolly b/c i ran the fan constantly. (HEY, IS IT THE "FAN" THAT IS SQUEEKING? WHAT IS THE "FAN?")
i'm getting a quote on replacing the blower motor.
Thank you Marty S.
-r
Tags
blower , fan , hvac , noise , squeek
Acceptable Blower Vibration John_NH HVAC 15 11-21-2010 01:49 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
inducer blower motor Noise snwboarder45 HVAC 5 10-05-2009 11:39 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 05:00 PM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 03:31 PM
