Furnaces Kill Me - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 09:25 PM   #1
Unhappy
furnaces kill me
i have a sushi store, and all the units work well except heating system,
it's a york comercial furnace on my roof top. the problem is it can't work proper, when i closed the braker, it only worked for 2mins then shut-off.
the service man said it's "flame sensor does not work" is that right????
another bad news: my house furnace didn't work either.
it's carrier high efficiency furnace,like 9 year old. it's same problem just like my comercial one. is this flame sensor problem as that one? i notice the LED flash 33 , means flame roll-out switch or fuse, so i used multimeter measure resistance between two metal legs was 0.08 ohm
did this mean bad fuse????? if not , the problem must on the flame roll-out switch.......
Oh God, furnaces kill me.......
furnacekillsme is offline   Reply With Quote
Old 11-16-2008, 09:30 PM   #2
oh, there is one more thing, my thermostat went out with furnace as same time.
i push every botton on thermostat,but i didn't see any reaction on it
Old 11-16-2008, 09:43 PM   #3
flame sensors in most cases can be cleaned not sure about commercial york but carrier uses the same type on their roof tops as they do in there home type(up to a certain size) the roll out switch unfortunitly probably means you need a heatexchanger but there could be other reasons why it tripped however when the flame rollout opens it means it could be a serious problem(carbon monoxide) and should be looked at professionally the good news is the heat exchanger is under warranty for either 20 years or lifetime but expect to pay 700-1000 for labor
the flame rollout is probably what made thermostat go blank as it kills the 24v to the stat
kennzz05 is offline   Reply With Quote
Old 11-16-2008, 10:58 PM   #4
thanks, i use multimeter to measure "COMMON 24v" but meter displayed 0
it's like what you say flame rollout kills 24Vs......
so, what i need do? try to push botton of FLAME ROLL-OUT switch?
cuz my house is getting cold , i really worry about my kids get sick.....
Old 11-17-2008, 09:01 AM   #5
Urban legend. Cold weather doesn't make for sick kids. It does make them tougher though and they will appreciate heat once it is back on.
You can either service the flame sensor which can have a build up of carbon on it and use some fine sandpaper to clean it up or you can replace it.
This is where I would start.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-17-2008, 11:07 AM   #6
marvin, the flame sensor prob is at the business the flame rollout tripped at his home
since im not comfortable adviseing him to reset it especiallywith kids i would advise calling in a professional
Old 11-17-2008, 11:40 AM   #7
I agree. I must have missed that point.
But I was right about the kids getting colds.
Old 11-17-2008, 04:10 PM   #8
Am I trippin. or do you guys hear an Oriental accent too.
Reminds me of a Popeye cartoon,,,
hvaclover is offline   Reply With Quote
Old 11-17-2008, 04:21 PM   #9
yea i certainly do and was while reading it but i couldnt say anything
Old 11-17-2008, 04:52 PM   #10
An old Tradesmen
Rewards Points: 7,318
Yes you are.
I have no idea where that wives tale came from.
Old 11-17-2008, 05:27 PM   #11
Originally Posted by beenthere View Post
Yes you are.
They relate the flu and colds with cold weather. When in reality the flu and colds is just more prominent in the winter because houses are closed up with people staying inside.
Staying inside is the wrong thing to do.
But you can't change people's minds so I usually don't try.
Old 11-17-2008, 06:56 PM   #12
dgbehrends's Avatar
Rewards Points: 150
Send a message via Yahoo to dgbehrends
Yes you are.
I either heard from someone or read somewhere that its not the temperature that makes you sick, but the change in temperature that makes you more vulnerable to become sick.
D in MN
dgbehrends is offline   Reply With Quote
Old 11-17-2008, 10:12 PM   #13
By hvaclover
Using tempo to kill spiders 4just1don Pest Control 12 09-24-2008 03:12 PM
How to kill a runaway plant or weed? bofusmosby Landscaping & Lawn Care 2 09-10-2008 05:31 PM
Furnace's blower is on all the time but gas burner does not start artgue HVAC 3 01-16-2008 05:46 PM
2 furnaces 1 thermostat clarnp49 HVAC 3 12-05-2007 08:12 PM
Payne Furnaces mick6311 HVAC 1 06-26-2007 09:10 PM
