Furnace Is Working But No Heat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 09:15 AM   #16
HVAC / Plumbing
Originally Posted by hvaclover View Post
Hey ken ....marty and dial up service.
~snicker~ dial up service
What's dial up ?? Thought That that went away with these
kenmac is offline   Reply With Quote
Old 09-11-2010, 12:43 PM   #17
Oh frac! You guys are worse than me!
hvaclover is offline   Reply With Quote
Old 09-11-2010, 01:21 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 2,270
LON, you may want to buy a differential manometer for the future. That furnace made by Nordyne has problems later with that plastic air supply fan slowing down/losing capacity. You need to know the "WC ability of it so when it slows down you can troubleshoot it. Did one last year and it develops intermittent pressure switch tripping codes. Let me know if you want to be pre-emptive and I can tell you how to deal with it. Without a manometer you cannot troubleshoot it.http://www.ueitest.com/product-em201.html
Good for checking gas pressures also. Homemade manometer won't work very well or at all with the low pressures that fan produces.
Old 09-12-2010, 06:08 AM   #19
Just like you said,spider eggs
Well I took the part off and cleaned it out like you guys said and it seems to work better than it did last year haha.This will help the electric bill because the furnace won't stay on as long as it did,she will heat the house faster.The spiders did a number on the small gas hole because I pulled alot of spider nest/eggs out of it.First I pulled some out with a tooth pick like I was told.It was a pretty deep hole so I stuck a long thin piece of solder down in it (went in about 3 1/2 inches) and moved it around to loosen the crap up then blew it out with a can of compressed air .She blows nice and hot now .,Thanks sooo much and i'll put the video up in a bit.Now I can finish rebuilding this,just crashed it a few days ago .
Lon1974 is offline   Reply With Quote
Old 09-12-2010, 07:27 AM   #20
Working good ,thanks again guys ..
Old 09-12-2010, 10:07 AM   #21
Tooth pick, solder, it's all good as long as you reached the obstruction.
Old 09-12-2010, 10:00 PM   #22
Yes and thanks again sir .
Ducane Furnace - no heat dave_in_waterloo HVAC 4 09-19-2012 09:41 PM
Heat pump or high efficiency furnace moisheh HVAC 13 11-14-2010 11:59 AM
Furnace room is warm, wasting heat Richo HVAC 13 02-18-2009 12:57 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 12:00 AM
