Furnace Won't Work - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 03:39 PM   #1
Rewards Points: 512
furnace won't work
Hi folks,
Hmm...my furnace won't go on, not even the fan. The programmable thermostat has low batteries. Would that cause a problem? There are only 2 wires going to it from the furnace (red and white) connected to RH and W respectively. Should I see any DC voltage on those wires?
canadaclub is offline   Reply With Quote
Old 03-09-2008, 03:54 PM   #2
biggles's Avatar
24V on those 2 wires at the subbase.to run heat...unscrew one and connect it to the other terminal,check the emergency switch and the CB panel..all ON.....you should have the burner ON.can you read voltage check the transformer secondary right off the color wires(yellow/blue)black/white is primary into it 115V
Old 03-10-2008, 01:40 PM   #3
HVAC Tech. - Family Owner
HVACguy's Avatar
As Biggles Said - I Would Jump Out Your R & W Terminal - This Will Bypass Your t-stat. If You Only Have 2 Wires To Your Thermostat There Is No "Fan On" Option, Unless Bypassed On The Circuit Board.
HVACguy is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 01:46 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
Gas furnace just barely does not work. Halcyon HVAC 9 12-27-2007 11:28 PM
Heil furnace Won't work. mgbarber44 HVAC 2 11-25-2007 02:34 PM
