Furnace Won't Turn On....no Power? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2009, 10:34 AM   #1
Furnace won't turn on....no power?
I've got a Janitrol GMP075-3 that overnight decided to stop working (and it's cold out). I'm no electrician but I've been able to eliminate a few of the possibilities.
  • Replaced the t-stat (previous unit was 10 years old and needed replacing anyways).
  • Checked and reset breaker.
  • Checked and replaced 3A fuse in the furnace.
  • Checked that furnace switch was in ON position.
  • Checked for any lose wires.
There is no pilot light, sounds, etc... and the status light isn't lit. While using the thermostat I was unable to get the fan to come one, AC to kick on, etc...
Any ideas of what it could be or where I should look? I searched and searched but couldn't find anything that would result in the status light not being on, besides power.
doningarden is offline   Reply With Quote
Old 12-01-2009, 03:43 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 402
You need to get someone to check if there is 120 volts at the furnace. May have a bad breaker or power switch. If you have never worked with live high voltage electricity call a Pro.
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Gas Furnace Power Venter Problem JoBlowHomeOwner HVAC 6 10-17-2009 09:05 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Furnace Help tuasoi HVAC 2 11-29-2007 12:54 PM
