Furnace Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 01:17 PM   #1
Furnace won't turn on
I have a Bryant, year 2002, model 340 MAV. A week ago, there was a real bad lighting storm. Lightning hit very close, and power was going crazy in house, on and off. I unplugged most things in the house, but a power supply to a sat switch did get fried,, in the same room as the furnace, and i could smell a electrical burn smell in the house. Maybe they are not connected, but now the furnace won't turn on. It is like it has no power, but i tested the wiring going to the furnace, and it has power going to it. The red light (that sends fault codes is not on), I do see a small 3 fuse on the circit board, but it looks fine. Was wondering if there are any other fuses to check, or could be something else.
Rippin_54 is offline   Reply With Quote
Old 09-16-2011, 01:20 PM   #2
JJboy's Avatar
Check if transformer is getting 110Vac and output 24vac.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-16-2011, 01:22 PM   #3
not sure how to do that
Old 09-16-2011, 01:29 PM   #4
JJboy's Avatar
http://www.youtube.com/watch?v=_HyhU...eature=related
Old 09-16-2011, 02:26 PM   #5
boy having trouble finding it
Old 09-16-2011, 08:46 PM   #6
bubbler's Avatar
Rewards Points: 256
those little glass cylinder fuses can appear to be OK but actually be burned out (sometimes they burn up near the metal part so you can see the filament broken).
If you have a multimeter I'd test each one for continuity. You can remove them from the holders, or just turn the switch on the furnace to off and test them in place.
bubbler is offline   Reply With Quote
Old 09-16-2011, 09:07 PM   #7
ok, tested transformer, and the black and white side of transformer, tests at 120 volts. The other side has a blue and red wire, and they have nothing. So i am guessing the transformer is shot. Now, none of the 4 wires to the transformer unplug, , they are solder in, just wondering how the new transformer will be. Also, didnt have power at all at first, till i figured out about the safty switch, i taped it down, then it sent power to the transformer, so least i know the switch is good.
I have a pic of the transformer, just cant figure out how to upload it here.
Old 09-16-2011, 09:22 PM   #8
JJboy's Avatar
some transformer has circuit brake switch on the body......check it
Old 09-16-2011, 09:43 PM   #9
checked it, and cannot see any kind of switch on it at all. Anyone know the $ on these transformers, and is it usual to have absolutly no power on the out side of the transformer?
Old 09-16-2011, 09:45 PM   #10
I'm Your Huckleberry
Rewards Points: 2,270
Can you possibly take some pictures of the transformer? I'd like to see these soldered wires.
Btw, if they truly are soldered and you can not simply remove the transformer via wire nuts, I'd just cut the wires long enough (so very close to the transformer) and wire nut the new wires from new transformer to the old wires.
Doc Holliday is offline   Reply With Quote
Old 09-16-2011, 09:48 PM   #11
Step down transformer around $20-ish dollars and yes, transformers blow with electriical "misfiring" so to speak, shorts and surges and the likes all the time.
Old 09-16-2011, 09:50 PM   #12
i took a pic, but for the life of me, i cannot figure out how to put it here
Old 09-16-2011, 10:07 PM   #13
When in the reply box click on the yellow square that looks like some sort of hard disc drive, just underneath the arrow which points counter clockwise. Then use a direct link in the box provided up top from your photobucket account if that is where the pic is. You'll need to erase the "http" thing that shows in the box first or at least I do.
If that fails or gives you too much trouble than cut 'n' paste works in the reply area as well.
Just copy the image and paste it in here.
Old 09-16-2011, 10:15 PM   #14
Don't forget to put an inline fuse on it to prevent this from happening again...
Danman5000 is offline   Reply With Quote
Old 09-17-2011, 06:07 AM   #15
ok, think i have this now. Sorry,i'm not the best with the computer.
http://s1101.photobucket.com/albums/...in_54/furnace/
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Gas Furnace won't turn on and smells like burnt rubber Jersey Pete HVAC 17 02-07-2011 09:11 PM
Old Furnace Igniter Sparks but pilot does not turn on Chak641 HVAC 5 01-11-2011 10:42 AM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 08:35 PM
