Furnace Won't Stop Running - HVAC - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 05:41 PM   #1
Furnace won't stop running
All of a sudden my electric furnace will not stop running. It just keeps blowing heat until I kick off the breaker. Even disconnecting the thermostat does not stop it. This is an old Intertherm electric furnace model MAC2454A in a mobile home. What could be causing this?
moundtown is offline   Reply With Quote
Old 03-15-2011, 05:47 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
stuck relay or sequencer
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-15-2011, 11:30 PM   #3
Two most common causes would be stuck sequencer or element coil that has broken or fallen down touching against the frame.
HVACTech79 is offline   Reply With Quote
Old 03-16-2011, 12:27 PM   #4
You guys were right. It was the sequencer. Changed and fixed. Thank you both very much for your help.
Old 03-16-2011, 09:24 PM   #5
Glad you got it going again. You're very welcome, happy to help.
Hot water won't stop running rickp47 Plumbing 8 02-19-2009 04:33 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
