Old 01-22-2008, 09:58 AM   #1
furnace wont stop curculating
when the thermstate shuts off the furnace keeps heating only in one zone. it shuts down eventually think it could be the honeywell relay that i replaced last year
jstp89 is offline   Reply With Quote
Old 01-22-2008, 06:03 PM   #2
Union HVAC Tech.
What kind of system is it? How many zones? How is it zoned? What was the relay you replaced for?
bigMikeB is offline   Reply With Quote
Old 01-22-2008, 06:52 PM   #3
Electrician
Is this a boiler or a furnace? and if it is a boiler is the boiler just shutting off on high limit but the tstat in not yet satisfied?
chris75 is offline   Reply With Quote
Old 01-23-2008, 02:06 AM   #4
its a bunham oil furnace two zones upstaires, downstairs
this problem is only happening upstairs. when heat is called for it starts curculating. when the thermostate is satisfied it just keeps curculating. but it does shut off at about 71 degrees, when the thermostate is set at 66. i even disconected the thermostate wires and it keeps heating. the relay is honeywell R8182D
Old 01-23-2008, 06:12 AM   #5
Union HVAC Tech.
It's a burnham oil fired "boiler". So you have two relays?
Have you opened both covers and seen if they are both pulled out when the boiler is running? If so look for a short in the burner circuit.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 09:38 AM
Bryant furnace won't stop clicking RichA HVAC 1 12-31-2007 03:41 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
