Old 04-02-2009, 05:36 PM   #1
Furnace won't stay lit
My gas furnace will light, then shuts off after 3-5 seconds. I have found this problem on several chat rooms, and the recommendation is to clean the flame detector. I did that and it did not fix the problem. I have since replaced the flame detector and still have the same problem. Does anyone have a suggestion for a next step?
Fleener is offline   Reply With Quote
Old 04-02-2009, 06:08 PM   #2
Hvac Pro
Post the make, model# and serial#.
Old 04-02-2009, 10:04 PM   #3
It is a Luxaire
Model - PACE-LD12N080A
SU/EN EMG06339
It has a B1 vent
Hope you can help!
Old 04-02-2009, 10:07 PM   #4
HVAC / Plumbing
Make sure you have a good connection on the wire from flame sensor & at the board connection
kenmac is offline   Reply With Quote
Old 04-03-2009, 08:39 AM   #5
30 year tech
hvac122's Avatar
Could be that the burners and crossovers need to be cleaned so that a good flame is hitting the flame sensor.
hvac122 is offline   Reply With Quote
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 05:14 PM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 09:30 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace Wont Stay On mccheese82 HVAC 6 12-16-2007 01:11 PM
