Furnace Wont Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 07:03 PM   #1
furnace wont stay lit
I have a carrier weathermaker 9200. I woke up this morning to a cold house under further investigation i found my furnace was not working. When i try to get it to run it will cycle, ignite run for about 2 seconds then shut down. I get a code 34 when it ignites it sounds like it pulses or surges?? then shuts off. please help it is going to be 9 below tonight
Mike
umdogs is offline   Reply With Quote
Old 02-02-2009, 07:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Check the intake and exhaust pipes outside for blockage with snow etc. If it is a 1 pipe unit (concentric) with a donut shaped hood, stick your fingers behind that hood and check for blockage there. Air goes in there. Check the drain hose from the furnace for kinks/blockage.
Old 02-02-2009, 08:21 PM   #3
I just checked the condensation trap and hoses they are all good. I checked inlet and outlet outside and they are clear as far as i can tell. I checked the inlet and outlet at the furnace and they look ok.
Mike
Old 02-02-2009, 08:47 PM   #4
Hvac Pro
yuri's Avatar
Those are difficult units to work on so I would recommend you call a reputable Carrier dealer. If they cannot come soon you may want to go to HDepot and pick up a few of those $20 fan heaters. I have worked on lots of them and there are at least 6 different non DIY issues which could cause your problem. If you are using propane is your tank full?
Old 02-03-2009, 11:08 AM   #5
Can't afford a repairman Thanks for trying to help i appreciate it.
Mike
Old 02-04-2009, 02:09 AM   #6
results?
kennzz05 is offline   Reply With Quote
Old 02-04-2009, 08:07 AM   #7
Still no go om the furnace. It will light run for about three seconds then shut down it will do it the three times then locks down and i get the 34 code.
Mike
Old 02-04-2009, 06:37 PM   #8
Doing some research the first thing listed to check for a code 34 is the flame sensor. I took it out like it said ( Is it the long thin metal rod with one wire) and cleaned it with sandpaper and still no go. Is there a way to test it or bypass it to see if this is the problem??
Mike
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 05:14 PM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 09:30 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace Wont Stay On mccheese82 HVAC 6 12-16-2007 01:11 PM
