Furnace Wont Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 09:57 AM   #1
furnace wont stay lit
it started out as it would have a hard time lighting it would take 3 or 4 cycles then it went to lighting for a few seconds then turning off the burners and go into watchguard mode. so i cleaned the flame sensor this seemed to fix it for a few heating cycles. i then replaced the flame sensor, now i get nothing not even opening the gas valve. so i switched back to the old sensor and it tries to light but wont stay lit. so i checked the pressure switch it is working i cleaned the hose and the condensation tube. now here is where i get confused, with the old flame sensor in i can jump the gas valve manually when the ignitor is at full temp and get it to light and stay lit with the jump, if i leave the jump on for 3 or 4 min. then remove it the furnace will stay lit in normal operation. if i shut it down and re start a few min later it will run normal operation, but if i leave it for 20 min. i will revert back to the symtoms above. with the new sensor in i cannot jump the gas valve and keep the fans on they shut off and the leds tell me the board is wired wrong. help please.
goatboy0067 is offline   Reply With Quote
Old 12-06-2012, 11:15 AM   #2
Furnace won't stay lit
Sounds to me as if it might be the gas valve. What is the model and serial number and make of the unit?
jnc401 is offline   Reply With Quote
Old 12-06-2012, 12:23 PM   #3
Burners,crossovers and grounds clean?
Old 12-06-2012, 12:53 PM   #4
lennox g50uh
i will be cleaning the burners shortly and i checked and cleaned all the grounds
Old 12-08-2012, 08:21 PM   #5
Hello new here but I like to help
Check the gas valve connections are making good contact.
Make sure you have voltage at the gas valve and it is constant not intermittent when you are calling for heat.
If the voltage is constant and the burners do not stay lit it sounds like the coil in the gas valve is weak and the valve will need replaced.
If you have anymore information it could help out.
Hope I was able to help you.
oncall is offline   Reply With Quote
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Goodman Furnace wont stay running handleonit HVAC 5 11-27-2012 09:53 AM
furnace wont stay on subcool HVAC 26 11-19-2012 07:52 PM
Gas Furnace will not stay lit... sobro HVAC 3 10-12-2010 09:22 AM
Furnace Wont Stay On mccheese82 HVAC 6 12-16-2007 12:11 PM
