Furnace Won't Start, Cent. Air Is Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2008, 03:21 PM   #1
Furnace Won't Start, Cent. Air is Working
Hello all and thanks in advance. My furnace is a Rheem Critron ll. It will not come on. It makes no noise like it is even trying to come on. It is not getting the signal to turn on. I have central air as well and it is controlled by the same temperature control and it is working fine. Any suggestions would be appreciated.
JThompson is offline   Reply With Quote
Old 10-01-2008, 05:51 PM   #2
biggles's Avatar
pull the stat and jump R to W on the subbase with a paper clip 24Vs no swet...nothing?go down to the furnace and jump the same R to W on the terminal strip in the furnace...nothing,do you have a flue damper with an end switch possibly.if you jump in the furnace there is something on the heating circuit solid state board with lights on it (getting 24Vs) maybe..you should get at least a spark (with the r-W jump) looking to ignite the pilot to start the sequence.
HEIL gas furnace will not start. Mikeee HVAC 11 01-11-2015 01:35 AM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 02:25 PM
start furnace without igniter??? repairrick HVAC 1 02-24-2006 09:45 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 06:10 AM
