Furnace Won't Start - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 05:28 PM   #1
MDA
Furnace won't start
We have a Lennox furnace, that will not start. It has two model numbers: on left inside of the furnice it says Model G12D2-82-2, with 65,600 BTU Cap. Below that it gives the servial nu. as 5789K03682. Just above the furnice on the aluminum it says Model C26-41N (with serial number 6001D51804. The furnace does not start. We replaced the termostat about 4 years ago with a White-Rogers programmable thermostat. With the control set on Heat and on Auto it does not start even though the requested temperature is higher that the actual. When the control is set for Fan On it does blow air, but the pilot light still does not start. What should I do? Thank you.
MDA is offline   Reply With Quote
Old 11-30-2011, 06:31 PM   #2
Rewards Points: 578
Iwould start by making sure you have voltage to furnace...breaker, on-off switch,fuse, these need ck 1st....
Old 11-30-2011, 10:59 PM   #3
MDA
Thank you. I do have power to the unit - the fan works. Do they still make fuses or just switches. There is power to the unit. What can I check next?
HEIL gas furnace will not start. Mikeee HVAC 11 01-11-2015 01:35 AM
Goodman Furnace does not always start JPM HVAC 14 11-07-2011 02:49 PM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 06:48 PM
Oil Furnace Won't start ScottEW HVAC 0 10-05-2010 08:26 AM
Heil furnace won't start - just a click and a hum MrGookat HVAC 4 01-06-2009 07:53 PM
