Furnace Wont Run - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2006, 10:13 AM   #1
furnace wont run
Help! I have a coleman oil furnace in my garage. I went out yesterday to turn it on,NOTHING. The breaker was o.k. I tried the reset, it didnt do anything,the stat was turned up above room temp.I hope its not serious, the furnace is 5 yrs. old, and worked fine last winter. I was thinking maybe the stat because it is dirty and dusty out there. My tanks are full & my main furnace runs fine on the same oil. I need some help with one! Thanks
pappabear is offline   Reply With Quote
Old 11-05-2006, 02:23 PM   #2
Does this model have a standing pilot light?
redline is offline   Reply With Quote
Old 11-05-2006, 08:06 PM   #3
No standing pilolight. It is your plane jane oil furnace.
Old 11-05-2006, 09:05 PM   #4
Thoroughbred Mopar Man
Rewards Points: 502
Hi papabear
I take care of a lot of waste oil heaters, They are the kind that burn used motor oil, transmission fluid, etc. Is this what your talking about. If not what kind of oil does it burn.
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 11-06-2006, 06:08 PM   #5
My furnace uses regular home heating oil.
Old 11-06-2006, 09:57 PM   #6
Rewards Points: 502
Hi again papabear
Are you talking about LP gas? I know that there are many names used for it but I can't help you unless I am sure of the fuel source. If its propane you might just need a hot surface ignitor, if thats so its easy to install. If you could let me know the model of the furnace that would help a bunch. It sounds like its a DGAA or a DGAT model furnace.
Good luck
Rusty
Old 11-07-2006, 02:18 PM   #7
It is a coleman oil furnace. Pretty much the size that is used in mobile homes.
Old 11-07-2006, 05:12 PM   #8
Rewards Points: 502
Hi papabear
I am going to take a stab in the dark that you could have a limit switch tripped. But thats as far as I am willing to go, I'm sorry to dissapoint you but I don't want to give out misinformation. There may be one of the others that have experience with this type of furnace. Going to let one of them help you. If it were a waste oil or a gas furnace I could help you. Once again sorry I could not help, if you don't get the response you need get ahold of your local HVAC contractor.
Good luck
Rusty
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
