Furnace Won't Run - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 04:33 PM   #16
Getting 120 volts to inducer motor still will not run pulled motor blower all one unit off very hard to turn then hooked 110 volts direct to motor nothing has to be bad inducer motor blower
fisk is offline   Reply With Quote
Old 10-03-2011, 04:48 PM   #17
JJboy's Avatar
Seems bad inducer motor. You can confirm this by doing continuity test. Be careful of the blower motor at this point you do not need to mess with it.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
