Furnace Won't Run - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 06:11 PM   #1
furnace won't run
my rheem 90 plus furnace will not start the combustion blower will not start and yes i do have power the two green lights are lit
fisk is offline   Reply With Quote
Old 10-02-2011, 06:19 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
two green lights on the board meaning normal operation on call for heat?
Doc Holliday is offline   Reply With Quote
Old 10-02-2011, 06:28 PM   #3
but the furnace will not run
Old 10-02-2011, 06:30 PM   #4
There are two electrical sides to all things air conditioning, your regular high voltage which is what produces the power for compressors and motors to do their work, and low control voltage. The latter tells the prior where to go and when, what work to do.
Question is, do you have low voltage.?
Old 10-02-2011, 06:33 PM   #5
You need a meter and some small wires or jumper gator clips. We can try bypassing a few things such as the stat and control board to see if heat comes on.
Does your a/c work? How about the fan only?
Old 10-02-2011, 06:34 PM   #6
yes I have low voltage
Old 10-02-2011, 06:35 PM   #7
a/c works and blower works combustion blower will not start up
Old 10-02-2011, 06:43 PM   #8
By combustion motor you must mean draft inducer motor. Nope, without that motor working you will not have heat as that is the first piece to come on in call for heat. We need to know if you have voltage to that motor. If yes but does not come on than it very well may be bad.
Sometimes they simply sieze up. Try spinning it by hand and see. If it gives resistance, tell tale sign it's out. Sometimes they work for a while longer if you can free it up.
Old 10-02-2011, 09:44 PM   #9
Check if there's a critter stuck in the inducer.
Old 10-02-2011, 09:48 PM   #10
My info was wrong. Sorry.
SS laser is offline   Reply With Quote
Old 10-02-2011, 11:21 PM   #11
Originally Posted by SS laser View Post
I am pretty sure on all 90+ furances the pressure switch has to close for the inducer to come on.
Old 10-02-2011, 11:23 PM   #12
JJboy's Avatar
Originally Posted by Doc Holliday View Post
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-02-2011, 11:29 PM   #13
HvacWiz's Avatar
Rewards Points: 252
Sometimes its better not to post at all
HvacWiz is offline   Reply With Quote
Old 10-03-2011, 01:37 AM   #14
Ok guess I am wrong. Sorry for the bad info. Just a tin knocker here.
Old 10-03-2011, 08:35 AM   #15
HVAC Tech/Owner
Rewards Points: 604
Not quite....but on some furnaces the board has to see the pressure switch circuit "open" before it tries to start or an error code results.
I am not up on rheem error codes but with green lights this failure mode doesn't sound like it.
Technow is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
